Used the Leon to Course open on an event over the weekend, which meant driving quite quickly down some rough country lanes for several hours, some very rough.
During the course of this the Traction control light and EML came on, I have scanned it with VCDS, and has thrown up a whole host of faults as follows.
Address 01 engine 5 Faults Found
17833-EVAP Purge Valve ( N80 )
P1425-35-00-Short to Ground
17525-Oxygen ( Lambda ) Sensor Heating Circuit: B1 S2
P1117-35-10-Short to Ground-Intermittent
17843-Secondary Air Pump Relay ( J299 )
P1435-35-00-Short to Ground
17829-Secondary Air Injection Solenoid Valve ( N112 )
P1421-35-00-Short to Ground
16486-Mass Air Flow Sensor ( G70 )
P0102-35-00-Signal to Low
Address 03 ABS Brakes 1 Fault Found
01314-Engine Control Module
013-Check DTC Memory
Address 15 Airbags 1 Fault Found
00532-Supply Voltage B+
0710-Signal too Low-Intermittent
Address 17 Instruments 2 Faults Found
01039-Coolant Temperature Sensor ( G2 )
30-10-Open or Short to Plus-Intermittent
00562-Sensor For Oil Level/Temperature ( G266 )
30-00-Open or Short to Plus
I can't help but think I have ripped off a wire underneath or pulled one off, or dislodged a plug or loom, in engine bay somewhere, or just shook something loose, some of the potholes we traversed were horrendous, after the recent weather
Anyone any ideas what I might have done to have caused the above faults, all in one go, one small upside, the N249 Mechanical Fault, I had before and after doing bypass hasn't come up lol.
I have cleared the faults, and driven the car in to town and back ( 8 miles ) all the fault codes have returned, the Traction and EML returned immediately upon starting, the car is not in limp mode, and is driving fine !!!!!
Cheers Chris
Cheers Chris
