Run Vag Com on my leon cupra t today and im getting 9 fault codes; 16486, 18058, 1689, 16885, 17978, 17545, 18010, 16684, 16688. dont think im being lazy as i have already read the fault codes thread (and have posted what the codes relate too) its just im not too sure exactly what they mean. the first code (16486) tells me the maf sensor, signal too low but i have only just replaced it, 2 days ago??? was wondering if someone could help me out and let me know what i have to do for each fault code to put it right. also is the car ok to drive with these codes on? thanks in advance. jordan
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 032 DE
Component: 1.8L R4/5VT 0001
Coding: 11510
Shop #: WSC 06441
9 Faults Found:
1) 16486 - 16486 P0102 Mass or Volume Air Flow Circ Low Input
2) 18058 - 18058 P1650 Data Bus Powertrain Missing message fr.instrument panel ECU
3) 16891 - 16891 P0507 Idle Control System Higher than Expected
4) 16885 - 16885 P0501 Vehicle Speed Sensor Range/Performance
5) 17978 - 17978 P1570 Contr.Module Locked
6) 17545 - 17545 P1137 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
7) 18010 - 18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
8) 16684 - 16684 P0300 Random/Multiple Cylinder Misfire Detected
9) 16688 - 16688 P0304 Cyl.4 Misfire Detected
Readiness: 0000 0000
Coding: 11510
Shop #: WSC 06441
9 Faults Found:
