Fault-code 01130 : ABS Operation Implausible Signal
Sep 18, 2020
20
Got the Traction Control, ABS light on and the Handbrake light flashing.
Error code 01131 - ABS Operation
Have replaced all wheel bearing and also all wheel speed sensors
Have also checked all the fuses, which seem to be fine.
Research suggests it could be the ABS control module is faulty.
The module that is installed is code: 1K0907379AD
Any tips on this? The units seem so expensive! and also require coding.
Any one else had this problem?
Cheers,
