Faul Codes Help
Mexicano
Engine Head
Oct 20, 2012
203
Mexico
Hello, I have an erratic engine every time I want to press the throttle, I got the following codes, PLEASE HELP!!!!!...this is not my Leon FR, It's my wife's Tiguan 2.0 TSI..
Address 01: Engine Labels: 06J-906-026-CCT.clb
Control Module Part Number: 06J 906 027 GD HW: 06J 907 309 A
Component and/or Version: MED17.5.2 TFSI 2 04 3409
Software Coding: 0423010A19070160
Work Shop Code: WSC 01357 011 00200
VCID: 73E5C7E51228D386965-8026
6 Faults Found:
008817 - Oxygen (Lambda) Sensor Signal B1 S2
P2271 - 000 - too Rich - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 21590 km
Time Indication: 0
Date: 2015.14.01
Time: 11:24:48
Freeze Frame:
RPM: 1831 /min
Load: 9.8 %
Speed: 97.0 km/h
Temperature: 97.0°C
Temperature: 39.0°C
Absolute Pres.: 770.0 mbar
Voltage: 13.843 V
000314 - Oxygen (Lambda) Sensor B1 S2
P013A - 000 - Response too Slow Rich to Lean - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 21424 km
Time Indication: 0
Date: 2014.14.27
Time: 16:25:24
Freeze Frame:
RPM: 1902 /min
Load: 11.0 %
Speed: 29.0 km/h
Temperature: 97.0°C
Temperature: 49.0°C
Absolute Pres.: 760.0 mbar
Voltage: 13.843 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 21439 km
Time Indication: 0
Date: 2014.14.28
Time: 16:06:14
Freeze Frame:
RPM: 2760 /min
Load: 99.6 %
Speed: 53.0 km/h
Temperature: 98.0°C
Temperature: 47.0°C
Voltage: 13.843 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 21439 km
Time Indication: 0
Date: 2014.14.28
Time: 16:06:14
Freeze Frame:
RPM: 2760 /min
Load: 99.6 %
Speed: 53.0 km/h
Temperature: 98.0°C
Temperature: 47.0°C
Voltage: 13.843 V
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 21614 km
Time Indication: 0
Date: 2015.14.02
Time: 07:26:44
Freeze Frame:
RPM: 3826 /min
Load: 96.0 %
Speed: 55.0 km/h
Temperature: 99.0°C
Temperature: 37.0°C
Voltage: 13.843 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 21545 km
Time Indication: 0
Date: 2014.14.31
Time: 13:13:17
Freeze Frame:
RPM: 3565 /min
Load: 93.3 %
Speed: 52.0 km/h
Temperature: 98.0°C
Temperature: 46.0°C
Voltage: 13.716 V
Readiness: 0000 0000
Joshkcupra
Local Retard
Aug 21, 2012
899
Gravesend, Kent
Your sensors in your exhaust have sprung a fault as by the looks of it there isn't a large volume of air travelling past the sensors, which is causing it to get too rich of a reading.
As for the misfire in the cylinders it could be a failed coil pack, or spark plugs..
Mexicano
Engine Head
Oct 20, 2012
203
Mexico
Thanks JoshKCupra....
Yes, the sensor fault is bacuase I installed a "Sport Cat".
As per the misfiring, I took out the sparkplugs and they look O.K., the car is only 20,000 Kms...I know anyways they can be bad, I will change them and follow with coil packs....how often the coil packs fails in 20,000 Kms.?
Thanks!
Mexicano
Engine Head
Oct 20, 2012
203
Mexico
You are not going to believe this: I just "sand cleaned" the spark plugs and gap them to .028"(They were at .030") and seems to be all right...
