scottj
Please help,
We have a model year 2000 alhambra 1.9 Tdi, (110bhp I think!) and everytime after starting the engine, the glow plug dashboard light stays lit for about 10 to 15 secs and then when I turn the ignition, the car revs all by it's own up to about 2500rpm (really load and embarrassing) and then settles back into a fast idle, at 1000rpm. This happens when the engine is warm, ie, first thing in the morning, car starts as normal, if we then park up and then restart the car soon after stopping, the above symptoms occurr. It's as if the ecu is not getting the message that the engine is already warm and thus too much fuel must be being injected and causes the over-revs.
Also, our coolant temp gauge has not worked correctly for years now, ie most of the time it does not move, but very rarely it does move up and shows a reading, then the needle drops down to zero degrees C again !
I suspect the coolant temperature sender has failed, but does anyone agree? also, where is this sensor on the engine please?
There are NO warning lights on the dash when this fault occurs.
