flashbsd
Martyn said:Mart, isnt Mike's car running the standard DP and zorst? He's pulling 15x's?
he has a cat back miltek, but on k03. 156i think it was.
Anybody willing to assist an old boy with his exhaust? and lend me theirs
Jonzy said:I think the phrase if a job is worth doing, it's worth doing properly comes into play here.
Proper half arsed attempt really, and you wonder why you've got problems!
m0rk said:*******s that drove your car from new
flashbsd said:http://www.seatcupra.net/forums/showpost.php?p=973643&postcount=1
Thanks martyn, if nobody closer to home have got one, i may grab yours off you.
I know, bang out of order aint they! could one of these 2 be a likely cause then? im hoping so. anyway to log exhaust gas pressure or anything?
Scotty_b said:Im guessing here but from logic id say it will be your zorst. As you had issues from day one and that’s the only thing left from the zero hour. That or there’s a blockage/issue further up the IC pipes away from the IC its self?
But iof the CAT was foocked and degraded it should brake down and therefore become more free flowing? Unless half has gone and is blocking the rest?
Flash I say go back to these original scallywags and say “You broke it you bought it”!
Scotty_b said:Which woud point to pipe isssue on the IC (Well i mean in a technical way to me) Or it could mean the cats fooked making the DP get uber hot! Sorry bit iof a pain arnt i!.
Flash your welcome to come and use the ramps etc around mine if you need any extra help as i have compressors etc (ow and an inspection pit, but its a bit damp!) plus a tripple garage, if you can move the landis over!
Martyn said:Mart, if m0rk gives you permission i'll bring the DP to the meet on Monday...
