Fan/air conditioning fuse
blackdream
258
I've problem with this fuse, If I turn on the air conditioning on position 1 everything works good. If I turn it on position 2 or more then the fuse broke. Anyone have an idea of why this happen? Also anyone know what fuse I need? there was a 30A one and I replaced with the same one but maybe it need a bigger one?
thanks
Mario
blackdream
258
guys this thing is driving me crazy. Everything works perfect on position 1 and 2, most of the times also on position 3 and 4. But the damn fuse still blown very often on position 3 and 4. Any idea?
blackdream
258
does it work with a/c off on 1234 ok ?
I thought it only happen when A/C was on but last time happened also with A/C off on position 4. I remember there is a way looking at a blown fuse to see if it is blown for court-circuit or for excess of power. Anyone remember the difference? I'll take a pic of the fuses...
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
commonly the heater rheostat speeds burn out and lose connection so may have melted across to earth and shorting out direct.
syptoms are losing 1/2/3 first as they are the resisted ones that take the grief so worth a look there too if it's popping fuses
also check check for current draw on the heater fan itself as that could be worn and causing the problem
