carl4x4
195
Just checked the tyre pressures for the first time on my leon TFSI, they are supposed to be 35 on the front and 32 on the rear. They were 35 all round, I guess there's a big pile of wheels at the factory that just get bunged on and pdi in the Uk didn't correct them.
Anyway might make the rear a bit less bouncy now they're not over-inflated you never know, could be worth checking if you've got a new Leon.
Good point haven't done that yet, or checked oil for that matter!! whoops
After i had picked mine up I checked the pressures so I could set the TPMS to the right value and found them all to be about 40psi, with the correct values being 35 n 32 like u said. After changing this i found the ride improved quite significantly with it becoming less harsh initially.
I think they have slowly gone down now as the ride becomes a little crashy when this happens.
Its def worth checkin them cus it does make quite a difference
