Fabia rear wiper arm
LE04HDB
51
Hi guys, can someone tell me whether it is the rear wiper/arm from a Skoda Fabia hatchback that is a straight swap on a 2004 Seat Leon Cupra.
Also if anyone knows if these are the correct part numbers?
6Y6955707 – Fabia Hatch Wiper Arm
6Y0955425 – Fabia Hatch Wiper Blade
6Y6955435 – Fabia Hatch Wiper Cover
Fisher
The arm and the blade are from a hatchback. The cover is from the Fabia estate.
Alexis27 is spot on with the part numbers, I did the mod a couple of weeks back..
6Y6955707A – Fabia Estate Wiper Arm
6Y0955425 – Fabia Estate Wiper Blade
6Y6955435 – Fabia Hatchback Wiper Cover
tsurumaru
Just to chip in, have had both non Bosch and Bosch aero wipers, at first was very happy with the non Bosch aero wipers compared to the stock ones (thats not hard) but they fairly quickly started smearing and it got pretty bad so eventually swapped to Bosch, haven't had any such problems since.
Nimzy
177
Yorkshire
Does anyone have a pic of fabia rear wiper arm fitted ?
There you are HTH
MK R BOY
139
Sorry Fisher Im confused now, you say arm and blade are from a hatch then quote part numbers the other way around??
Which ones should I go for, sorry if I have misunderstood.
Lee
dgjdrummer
Part-timer
Nov 5, 2011
1,310
Wrexham, N. Wales
Hey Lee,
the part numbers Fisher quoted are correct, search ebay for item: 120846493041
This includes:
6Y9955707A – Fabia Estate Wiper Arm
(the hatchback cover has the washer jet opening where the estate would not)
That's the 3 parts for £19.99 delivered.
HTH
wbaxter90
49
just get the ebay one from the link above, i did. cheap, easy and genuine parts without the hassle of making sure you get the right ones.
Dec 31, 2007
1,479
Reading
Lee
Lee, you want the hatchback cover and estate arm and blade. The part numbers are correct, just the narrative the wrong way round!
andycupra
status subject to change
can you edit this? your text contradicts the parts list/description...
My understanding for the mix of parts is that the leon rear wiper spray come from the wiper base, whereas on the fabia estate it comes from above the windsreen, so we need to fit the hatchback cover so we can still use the spray as the estate one does not have the cut out..
PABs did a great description and guide here:
http://users.skynet.be/tdi150/id40.htm
