F.A.O. people with AP coilovers...
dave parker
61
Am looking at these for my 2013 Ibiza TOCA and am wondering if you need shortened droplinks?
Some manufactures say you do some dont, but I cant see for deffo if AP do
They only go 60mm drop max on lowest setting, I will probbaly be around 40-45mm
Cheers :D
eightball103
weirdo
May 2, 2014
84
I know with the mini that any drop at all meant lots of adverse camber on the wheels, a set of adjustable drop links dont cost the earth and are worth it if you dont want to be buying new tyres every 6 months...
DEAN0
Old Git
Feb 1, 2006
5,419
Preston - UK
Drop links do not affect the camber on the Ibiza. You only change them so the anti roll bar does not rub on the driveshafts.
To adjust the camber on an Ibiza you would need adjustable strut top mounts or different length lower wishbones.
DEAN0
Old Git
Feb 1, 2006
5,419
Preston - UK
There you go. More words of wisdom than I could muster :p
Sent from my Nexus 4 using Tapatalk
I still can't answer his question though.
I don't know if the AP kit needs different drop links OR if the drop link mounts are moved so you use standard drop links.
