exhaust options
sloppycupra
Nath.....
Apr 16, 2006
81
right guys i ave a k03s ibiza cupra with 3" d/p and 100cell cat, it also has a scorpion 2.5" exhaust with 4 " tail pipe,
what i am after is for my exhaust to be louder??
can i remove the middle box if it has one?? will this affetc power?
also could i change the backbox or is it an all in one sytem?
opinions and advice would be much appreciated
cheers Nathan
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
cheers Nathan
U can change the back box ok, Ive got a scorpion on mine, Twin 3" pipes.
Very loud, Big back drop on it & lots of popping.
Dont know how loud yours is so cant compare but its a lot louder than miltek exhausts.
sloppycupra
Nath.....
Apr 16, 2006
81
ok thanks guys think i am going to drop the exhaust of later and way up the options think i will weld a pipe in to remove middle section then see how it sounds before i swap back box
will removing the middle section not affect performance as i know the boxes are nedded for N/A cars
cheers again
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Also another note is your exhaust tip, if its baffled (the tip not the box) it will quieten down the rasp that the engine produces. The Blueflame and Miltek both have baffled tips, if you replace these with cheap non-baffled tips you'd get a bit more noise.
