Exhaust knocking
huwwatkins
I've had a problem with my Coroba for a few months now, its a 2.0 16v sx. However the centre section keep benging in to a plate that is bolted horizontally across the underside just behind it. Is this a common problem on these cars? Can the plate just be removed?
Huw
huwwatkins
Hi
Its not the heatshield, its a plate that sites right behind the centre section , the pipe out the back of the centre section goes over it. Its about 5 inches long and its held on by two nuts either side.
andyj
There's no F in Quality..
sounds like one of you rubber exhaust hangers has perished, causing the exhaust to drop.
they're not that expensive IIRC.
Think the bracket is there to hold the exhaust up if the mounts fail all together, like in your case. Otherwise the exhaust would hit the floor, and is potentially dangerous.
huwwatkins
Hi
first thing I did was replace all the rubber mounts - the two on the back box and the one on the centre section.
