Hi guys
I have done a search on this, found some answers to what i was going to ask but the main question is still unresolved.
I had my car scanned for faults earlier today and one thing flagged initially was Exhaust Gas Temp Sensor - Closed Circuit, I take it this means I need a new EGT sensor or is there more to it than that.
Also prior to having my map, I was getting some quite bad surging to the extent it would go to 20psi, it would never hold here just surge, boost was held around 10. This has now been overcome I'm hoping but Will at P-Torque noticed some irratic readings from the N75 just prior to loading the map and he has tweeked something to do with this manally to an extent rectify it but told me to keep an eye on my boost gauge to make sure boost isn't going to high (now boosts to 24/25ish/not actual sure what it holds at yet, haven't thought to look). Wihout seeing logs i know it's hard to say but would you say there could be an issue here more than likely. Oh and is the standard Cupra R n75 the 'F' verson
Any help or advice from someone in the know is appreciated on either subject, thanks in advance
