Hi all,
cars developed a new problem
about 2 weeks ago I had a resonated centre section fitted to my 3" cobra turbo back as it was a little loud. before It went in to be fitted I told them the exhaust was blowing from where the backbox joins onto the centre section they said when they fit the new section they will have to replace the gasket anyway so they did this and the blow went but they said I seem to have a minor blow around the front of the car but they cant pinpoint it without taking the car apart so I left due to lack of funds, after a few days its getting irritating! I don't believe its anything they have done its probably been there the whole time but now all the leaks have been fixed and the exhaust is somewhat quieter its making the blow at the front sound louder and worse! and now im getting exhaust fumes enter the cabin if I have the heaters on!
you can really hear the turbo noise a lot more and when you first start up in the morning on choke the blow is worse then after a few minutes it will go quieter
so im thinking:
*cracked manifold
*loose manifold/gasket
*turbo to manifold gasket
*downpipe
does anyone know what its likely to be?
had a little look under the bonnet yesterday to see if I could see any obvious leaks and I couldn't see none. Im planning on getting underneath it Friday aswell to see if anything obvious there.
then today while driving the engine management light comes on.
plugged it in and comes up with
P0136 -
Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2)
P0036 -
Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Malfunction / Open Circuit
is this a coincidence these fault codes have come up or is it because I have a blow somewhere within the front of the exhaust system?
so im thinking:
*cracked manifold
*downpipe
P0136 -
P0036 -
