evap removal?
SeatR
399
Norway, Bergen
hey, need som advice here when im removing my evap system.
The red arrow shows a rubber hose and a hardline which goes down to the turbo and mounted on the turbo inlet pipe ! should I just remove this and block the pipe?
will this removal effect MOT?
adulka
116
hi
i want this too removed, but i have again a few questions :whistle: :D
so: this hose from manifold must be blocked, then blocked this hose, which go to TIP
then removed EVAP canister and all hoses. Then hose, which go from tank give out (be somewhere under the fender) and on connector give resistor?
its ok?
May 25, 2008
2,400
cambs
Yeah but it will give the occasional code
I've left mine plugged in and traced the wiring back under the scuttle panel to conceal it
