Errors and coding - correct?
May 1, 2020
7
Hello, I am giving log whether encoding is correct? I mean xenon lights and a twist sensor.Because they do not light the steering lights when turning the steering wheel xenon and fog.
Mileage: 61390km-38145mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 4B 55 56
VIN: Mileage: 61390km-38145miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GR HW: 03F 907 309 AE
Component: SIMOS10.22AH10 5485
Revision: --H10--- Serial number:
Coding: 001100D6202400080000
Shop #: WSC 00049 770 00143
ASAM Dataset: EV_ECM12TFS02103F906070GR 004007
ROD: EV_ECM12TFS02103F906070HB_SE25.rod
VCID: 78FF5DE7C3D3424633-802C
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 AQ HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 10DD287D212C00C5081D146B845100000404
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0D111C33DC5157EE70-8058
1 Fault Found:
1056 - Coding Not Possible
U10BC 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 61398 km
Date: 2020.05.01
Time: 08:56:58
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 30011404650638
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C7679-802A
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6J0 820 043 E HW: 6J0 820 043 E
Component: Climatronic H03 0808
Revision: S0000000
VCID: 2643439F51E704B651-8072
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 018140729
Coding: 67812BB8D861000001300E757F8F97C80EC067EB608D7051240000030000
VCID: 2D51BCB3741137EE90-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 080114 05 54 0403
Coding: 0A242D
Subsystem 2 - Part No SW: 6R0 959 801 AK HW: 6R0 959 801 AK Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 5110
Serial number: 13202559140127185819
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 AR HW: 6R0 959 802 AR Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 5110
Serial number: 13102562140127204011
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 K HW: 6R0 959 811 K
Component: J388__TSG_HL 006 5110
Serial number: 13202567140127171021
Coding: 000000
Subsystem 5 - Part No SW: 6R0 959 812 K HW: 6R0 959 812 K
Component: J389__TSG_HR 006 5110
Serial number: 13202566140124032531
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels:| 6J0-919-475.clb
Part No SW: 6J0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H09 0016
Revision: -------- Serial number: 32901402101122
Coding: 100002
ASAM Dataset: EV_SE250ParkiAssis2 S01711
ROD: EV_SE250ParkiAssis2.rod
VCID: 377D9EDB8E4D8D3EFA-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA09 H10 0020
Revision: -------- Serial number: 003GX020PZ6Y
Coding: 003039
Shop #: WSC 00049 770 00112
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00D695-801E
Crash sensor for side airbag: driver side:
Serial number: 3495RRB400K50S02HPQ+
Crash sensor for side airbag: front passenger side:
Serial number: 3505RRB400Q50S00JHQV
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 6J0 920 806 K HW: 6J0 920 806 K
Component: KOMBI H31 0302
Revision: X003115S Serial number:
Coding: 11EF22
ASAM Dataset: EV_KombiUDSMM9RM10 A04752
ROD: EV_KombiUDSMM9RM10_SE25.rod
VCID: 3467A9D79F3B6626DF-8060
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 022200
VCID: 70EF65C7A3A31A06FB-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 6J0 920 806 K
Component: IMMO H31 0302
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6ADB77AF8D7FE0D6B5-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10141
Shop #: WSC 12345
VCID: 306FA5C7F7235A06BB-8064
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 77005 000 00000
VCID: 3169A0C3A829530EB4-8064
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0147
Revision: 00H04000 Serial number:
Coding: 2688103
Shop #: WSC 12345 111 45725
VCID: 3B7582EB7E65A95E1E-806E
Subsystem 1 - Part No: 7L6 941 329 C Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000041
Subsystem 2 - Part No: 7L6 941 329 C Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000041
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 6J0 035 156 HW: 6J0 035 156
Component: Radio H09 0014
Revision: R0000000 Serial number: SEZAZ1P6499448
Coding: 0000000A0100
VCID: 64C71997675BB6A68F-8030
End-------------------------(Elapsed Time: 02:43)--------------------------
Address 03: DTCs cleared
