Error Code Help please
~Divine~Wind~
Newbie Owner
Sep 6, 2011
74
hey Guys,
Well with many thanks to TheDean who managed to get his laptop hooked upto my car I have now found out I have the following error codes:
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
VCID:
4 Faults Found
01271 - Positioning Motor for Temperature Flap (V68)
000 - - - Intermittent
01272 - Positioning Motor for Central Flap (V70)
00792 - A/C Pressure Switch (F129)
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 16524
Shop #: WSC 06402
VCID:
3 Faults Found
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 62 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
VCID:
3 Faults Found
00819 - High Pressure Sensor (G65)
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: J2 Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
VCID:
Part No: 6Q1959801A
Component: J2 Tõrsteuer.FS KLO 0003
Part No: 6Q1959802A
Component: J2 Tõrsteuer.BF KLO 0003
1 Fault Found
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
I have no clue about these other than my central locking appears to be working fine lol.
Do any of the above indicate any issues with the Lambda?
Im currently searching on all of the above.
Not too bothered about what appears to be AC stuff.
And I didnt even know the car had AWD, does that mean the traction control?
I've removed the VCID's as I wasn't sure if they were unique to my car or not.
Any help appreciated.
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
That has to be the door lock mechanism unless there's a seperate solonoid for the locking, more likely the little micro switch in the lock playing up probably.
I think that's what a mate had in his polo, he fitted a new motor assembly and flap etc for the heater which cured it.
I don't see anything relating to the lambda there, are you having a specific problem with the cars running? Also what kind of car is it we're talking about?
~Divine~Wind~
Newbie Owner
Sep 6, 2011
74
Seatmann, thank for the fast reply :) much appreciated
2.0 Sport Ibiza Mk4
Previous readings from cheapy handheld jobbies both came back with lamba errors.
I averaging high 30 - low 40 mpg, the only issue is the damn EML on the dash lol
The only other thing that does annoy me is when the central locking is unlocked I have to unlock the passenger door with the switch inside on drivers door.
~Divine~Wind~
Newbie Owner
Sep 6, 2011
74
MPG imho is fine yeah, just worried that these errors could cause a serious headache is all.
Just bought it and the first thing that came on was the EML Doh!
shep0706
243
Darlington
My car was like this when i bought it , id make a note of all the codes for reference then clear them and then check the car again in a few days.
