Hi,
I had my Leon Cupra TDI scanned for the 1st time yesterday (owned the car for 3 years) as the engine warning light has been on for a week and it has been struggling to start.
I have changed the glow glugs and battery about 8 months ago, but over the last week or two its not starting. When I try to start it, it completely dies like the battery is dead. I have tried the old battery that I replaced and it does the same thing.
Anyway here are the codes from the scan. (Theres a lot)
Mileage: 237090km-147320mi Repair Order:
Chassis Type: 1M (1M - Seat Leon (2000 > 2005))
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
Address 01: Engine Labels: 038-906-019-ARL.lbl
Part No: 038 906 019 KG
Component: 1,9l R4 EDC 0000SG 5342
Coding: 00002
Shop #: WSC 06402
VCID: 66C346640263FB11F57-4B02
VSSZZZ1*****
2 Faults Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 35-10 - Electrical Fault - Intermittent
18080 - Coolant Fan Control 1
P1672 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001 001 00001
VCID: 326BEA34AE2B57B1A9F-5140
1 Fault Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00044
Shop #: WSC 06402
VCID: 24471C6CB4DFC9012B3-2580
2 Faults Found:
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06401
VCID: 224B1A74AECBC73159F-5122
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00608
VCID: 3A7BC214265BAFF161F-4B02
Subsystem 1 - Part No: 1C2959802A
Component: A7 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C2959801A
Component: A7 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: A7 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: A7 Tõrsteuer.HR KLO 0202
8 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
01331 - Door Control Module; Driver Side (J386)
52-10 - Supply Voltage Too High - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01359 - Internal Central Locking Switch; Passenger Side (E198)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
00931 - Locking Module for Central Locking; Rear Right (F223)
Any advice is welcome and if anyone has had similar issues, what did you do etc. I have had a look on the code finder and got a list of things to check but thought id post on here for any further help.
(I know the door module is faulty as the central locking is broken)
Coding: 00002
Shop #: WSC 06402
VSSZZZ1*****
2 Faults Found:
Coding: 0022017
1 Fault Found:
Coding: 00044
Shop #: WSC 06402
2 Faults Found:
Coding: 13113
Shop #: WSC 06401
1 Fault Found:
Coding: 00259
Shop #: WSC 00608
8 Faults Found:
