brad1
hi all
i know what to do but i not quite sure, my radio code in 9014 but i only have buttons from 1-6 on my radio, how do i input 9 etc?
help
You only use the 1, 2, 3 and 4 keys to enter the code.
To enter a '9' you have to press the '1' key nine times. Assuming you start with 0000, to enter your code you press...
1 1 1 1 1 1 1 1 1 3 4 4 4 4
When you've got the correct code displayed, press the 'PROG' key. It says in the manual to press it briefly, but I had to hold the key down for a second or two for it to register. I'm not sure if that's normal.
Ok here it goes folks again, I'm helping because I was very frustrated with mine for a month. I got the following info from my dealer in Mexico via telephone. NO CHARGE. He informed me that the code might be under the ashtray. Pull out the ashtray and there might be a sticker under the ashtray with the code. It may be on the side of the radio unit or in the glove compartment. My code is 0777. Anyway turn your stereo on (car off) then wait for an hour!! no key inside ignition either! come back your display should have changed from SAFE to 1000. Then input the code first and then press the SCAN button and that's it!!! good luck, did mine yesterday!!!!
