Sep 24, 2024
Hey,
I'm about to buy second hand ibiza 2021 reference 1.0 automatic
And everything just fine but while idle or driving slowly the engine is vibrating
Is it should be like that or there is a problem and if so what it may be?
Thank you
Lots of posibilities. Tickover too low, Combustion out of balance - plugs dirty / fault, low voltage ignition fault, HT vo;tage ignition fault, anti vibration mount fault, engine fault - crankshaft, bearings, pistons, gearbox fault, petrol supply fault, etc. The list goes on. Could be cheap or very expensive to fix. Suggest you be wary, particularly if it is a private sale. Is there a service record?? This can be obtained from a Seat dealer, if it has been serviced by Seat.
