Hi Guys, at work currently so unable to look thro manual, so wonder if tdi owners can help.
Started car this morning, bit sluggish due to temperature (0 degrees) dash beeped, checked and the outside temperature gauge showed snow flake and 0.0. not a problem.
However engine temperature light was flashing red, which was cause for concern.
All sounded and felt fine. Stopped engine and restarted, did not re-occur.
Any ideas what this could be warning me about ?
Have driven to work and temperature in cabin increased as did engine gauge temp.
just been to give car a once over and appears fine, coolant level/oil, no visible leaks ?
started up fine, so any thoughts
cheers
cheers
