Engine Temp warning?? OMG! Advice pls
Atlantia
127
The South West
Cold evening, started the car, drove for about 2 minutes and was stopped at traffic lights. Girlfriend was playing with radio which was coming on on its own, suddenly BEEEEEEEEEP and a red light next to temp guage flashing!!
Gauge still reads cold, needle not moved from 60. Light went off after a few seconds, started driving again and after another minute or so the needle starts to climb, after another minute or so its at 90 and stays there no further problem.
Well apart from my nerves! Can they make these warnings any louder?
Anyone know what the hell that was all about?
Dodgy thermostat?
adam20vT
53
mines been doing the same but ive got a cupra. i've been told my exhaust gases smell eggy aswel?? any ideas or help. dont mean to steal post.
Atlantia
127
The South West
Thanks TruCido,
Long as its not anything awful.
I've had the car nearly a week now and it was my first experience of the subtle warning!
I was so freaked out that it was only the cars behind me beeping cos the lights had turned green that shocked me back to reality!
I'll check the levels tomorrow, thanks.
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
As said, light usually comes on when your coolant level is low.
as for egg smell, doesn't necessarily mean you're overfueling, it just means that unburnt fuel is getting into cat, and when it gets hot there, it smells like egg. Most realistic cause is a dodgy coilpack as mentioned, which is not burning the fuel efficiently or at all in one of the cylinders.
hope that helps
andycupra
status subject to change
its common issue.
did it bleep 3 times?
its the coolant level. this is why you dont have issues with coolant temp, as its the level. They use the same warning light.
Options are:
1 Top up the coolant a bit.
2 Replace the expansion tank which includes the sensor.
3 Take top off expansion tank, (when cold) look inside there are two metal prongs from teh sensor. Lightly scrape these with a screwdriver or the like. This can often help. Whether its cleaning them or just the fact this wiggles them a bit im not sure.
4 remove the sensor and check the connections are clean.
If i was you id do 1 and 3. possibly 4 and then see how it goes.
Atlantia
127
The South West
its common issue.
Options are:
Brilliant! Thanks mate, will do. :)
andycupra
and to clarify, it may be that the level isnt low, but these sensors appear to get very fussy when its cold, so get the lever towards the top of the range. (which may then be above the max line when the coolat is hot, but dont worry).
cletus
yeah my cupra does it aswell topped up the coolant and it solved it for a while. only does it now and again when it very cold out. hoing to replace the tank cos the sensors are very common on the vag vehicles.
Apr 15, 2009
2,189
Midlands
I used to get bad eggy smells when i used a turbosmart dv, changed to 007p and has been fine since
What dv are you running?
Also the beeps normally low coolant yer
