In need of a bit of help...
A while back I went to start the car and it would just not fire up as if there was no fuelling or immobiliser fault, It did it again the other morning when we had a lot of rain and left it 10mins and was absolutely fine again so just ignored it.
Last night ran vagcom for some faults and found: 16705 - Engine Speed Sensor (G28): Implausible Signal
After reading this cuts out any fuelling as a safety feature so explains the starting issue, it’s only done this twice over last few months so thinking maybe just a connection problem and may just need the senor having a good clean.
I’ve tried to find some more info on the sensor but can’t seem to find any, does anyone know where this is located? Is it by the oil filter on the bottom of the block?
Thanks!
Mat
Thanks!
Mat
