DannyFR
I seem to be getting various engine smells comming through the vents. Its been like this since i got it. Any ideas?
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
air con on?
if nto used for a while it can be the air con.
Mine does exactly the same. It smells a bit like burning, but its not a clutch smell. It will probably be the air-con system. Most engines have a heater hose which comes from the engine to heat the cabin. My guess is its that you can smellIts really annoying though. Mine seems to happen when driving from work (straight onto dual carriageway at 70mph)
