hi, the engine shakes quite violently at idle. Doesn't matter if the car is up to temperature or not.
Doesn't seem to do it as much if I keep on the throttle slightly to increase the idle speed.
It has recently just come out of a garage with a new DMF & clutch, which they said was the cause of the problem.
Is it something else? Or did the garage just do a bad job?
It's going back into the garage on Friday morning to have a look, but until then I wanted to get some independent opinions.
