I found a list of what each measuring block contains on the internet (albeit from a guy with a Passat but it looks pretty much the same as my LC), so I've messed around and recompiled it to try to make it easier to find which blocks contain the things you want.
If anyone spots any mistakes please let me know. Also if anyone knows how to format it to look neater? (It was copied and pasted from Excel).
Hopefully it might help someone...
Code:
A/C Compressor Mode 50
Active Camshaft Adjstment Angle 91
Actual Adaptation Value Boost Press Control Valve 119
Actual Charge Pressure 115 118
Adaptation Condition 60
Adaptation Step Counter 60
Adaptation value 55
Adaptation Value at Idle 32
Adaptation Value at Part Throttle 32
Adjust for Basic Settings 1
Adjustment 91
Air Conditioner Mode 50
Air Mass - Secondary Air Injection 77
Air Mass Drawn In 77
Air Mass In 2 3
Air Pressure 113
Altitude Correction 6
Amplitude Ratio 46
Average Injection Time 110
Boost Pressure Before Throttle Valve 119
Brake Booster Pressure 8
Brake Condition 8
Camshaft Adjustment 94
Catalytic Converter Temperature 34 43 46
Condition Reed Contact 71
Coolant Temperature 1 4 11 28 99 100 102 110
Current Engine Load 114
Current Engine Load (torque) 120
Cyl No. 1 Retard 22
Cyl No. 2 Retard 22
Cyl No. 3 Retard 23
Cyl No. 4 Retard 23
Cylinder 1 26
Cylinder 2 26
Cylinder 3 26
Cylinder 4 26
Delta Lambda 37
Diagnostic Status 71 100
Driving Range 51
Duty Cycle Boost Pressure Control Valve 119
Duty Cycle EVAP Canister Purge Valve 70
Duty Cycle, Wastgate Bypass Valve 114 118
Dynamic Factor of O2 Sensor Pre Cat 34
ECM Voltage 4
Engine Idling Speed 107 113
Engine Load 2 5 6 10 14 22 23 28 37 91 113
Engine Speed 14 22 23 28 34 43 46 50 54 55 56 91 120
Engine Speed (Spec Value) 50 56
Enrichment Factor Bank 1 112
Enrichment Factor Bank 2 112
Exhaust Gas Temperature Bank 1 112
Exhaust Gas Temperature Bank 2 112
Fault Message 71
Generator Load 53
Idle Control 55 56
Idle Speed 1 2 3 4 5 6 10 11 77 94 99
Ignition Angle 3 10 11
Ignition Angle Retard Cyl. 1 20
Ignition Angle Retard Cyl. 2 20
Ignition Angle Retard Cyl. 3 20
Ignition Angle Retard Cyl. 4 20
Ignition Misfire, Cyl. 1 15
Ignition Misfire, Cyl. 2 15
Ignition Misfire, Cyl. 3 15
Ignition Misfire, Cyl. 4 16
Immobolizer ID 81
Intake Air Temperature 4 6 11 102 118
Lower RPM Limit 18 18
Mean Injection Time 2 102
Misfire Recognition 14 15 16
Number of Ignition Misfires 14
O2 Sensor Control 99 107
O2 Sensor Control - Deviation for TVV Diagnostic 70
O2 sensor heating after catalyst 41
O2 sensor heating after catalyst, resistance 41
O2 sensor heating before catalyst 41
O2 sensor heating before catalyst, resistance 41
O2 Sensor Reg Pre Cat 33
O2 Sensor Voltage Post Cat 36 43
O2 Sensor voltage, O2 sensor after catalyst 37
O2 Sensor voltage, O2 sensor before catalyst 33
Operating Condition 55 56
Operating Conditon O2 Sensor Control 99
Operating Mode 5 54
Oxygen Sensor Reg Pre Cat 1
Pump Condition 8
Readiness Code 100
Result of Operating readiness 36
Result of Test 94
Road Speed 5
RPM 102 110 119
RPM Actual Value 51 53
RPM Specified Value 51 53
Sender 2 for Accelerator Pedal Position 62
Specified Charge Pressure 115 117
Specified Engine Load 114
Specified Engine Load (torque) 120
Specified Engine Load After Correction 114
Start Engine Temperature 104
Status 120
Status Post Cat 30
Status Pre Cat 30
Supply Voltage 51
Temperature Adapt. Factor 1 104
Temperature Adapt. Factor 2 104
Temperature Adapt. Factor 3 104
Test Result 8 28 34 37 43 46 70 71 77 107
Throttle Drive 113
Throttle Position 54 62 117
Throttle Valve Angle 3 10 110
Throttle Valve Angle (Sensor 1) 54 60 62 117
Throttle Valve Angle (Sensor 2) 60 62
Time Since Engine Start 100
Upper RPM Limit 18 18
VIN 81
Voltage 53
