engine management light came flashing on and no turbo power.
c6hut
Got a 2004 LCR, driving it home tonight, admittedly I was giving it some, and all of a sudden the engine management light came flashing on and there was no turbo power. The light then went back off again, but as soon as I accelerated again any higher than around 2-3k revs the light come back on again. Stopped when I got home, the car is lumpy as anything and there was a funny smell, but not smoking.
Hope this has happened to someone else, any ideas would be helpful
cheers
Mar 26, 2007
2,020
S.Wales
Could be so many things mate, you need to get it diagnosed asap.
Either take it to a good independant or get it scanned with vag com.
Pabs
5,936
Basingstoke
Initial basic checks - all hoses present and correct, none popped off - check intercooler hoses and turbo hoses.
Check coilpacks are seated properly - one could still be faulty tho. As mentioned - Diagnosis via VAG-COM is easiest.
swilky23
230
rochdale
I got exactly same prob pal i put my vag com on an its 16684 random misfire(coil pack).
sounds like a tractor and no power!!
c6hut
Took it in today, Yep coilpack, £45 later and its all gravy, cheers for the help.
Found more problems, but thats another story....
