any local garage in the area with a diagnostics machine which is
OBD compliant will be able to check this for you. many places have them now. kwik fit and many local independent garages.
What you have to look out for is if you have had any previous problems which have been logged on the ECU and come up on the scan. you will have to find out which one is causing the new
problem you have because you may have 5 codes come up for example but maybe only 1 or 2 will be the
problem.the other codes may be from before if somebody hasnt erased the codes from the ecu memory. so clear the codes take the car for a good test drive and see which fault codes come back.
