basically i was driving down lanes when my car spluttered and had no power as if as coil pack was going, then no power, wont rev and just died! tried restarting it and its like its not turning over the engine, ie no compression, sounds normal for the first split second of turning the key then it turns over really fast but makes no attempt to start, so opened the bonnet and it smells abit like antifreeze ??? have checked all levels and there good also checked oil for foam and all is good all the temps are reading good aswell, also if i turn the ignition on and wai for all the lights to go off then try to start it the abs and tcs light come on???
is this normal?
cheers for the help
coxyboy
is this normal?
cheers for the help
coxyboy
