Well I thought I would make a direct thread about the engine fans coming on when you start the car. My LC started doing this a couple weeks ago at 1st I noted it down and forgot about it until I saw this thread http://www.seatcupra.net/forums/showthread.php?t=247496
I have had it about 5 weeks now and we have had cambelt/idle kit, maf sensor, new interior fan fitted although this was suppose to be a centre blower since that was the issue but they have changed the fan "doh".
Anyway it was when the maf sensor played up i noticed it but why is it doing it I take it its NOT normal ?. Do you think the water pump is faulty. It sits at 90 and doesn't get any hotter but then the fans are on so if these were not on it may get hotter ?.
I wouldn't even try to start it today since its all frozen for like 2 days now the cooling fans are most likely to come on making it very cold and don't want to damage nothing :<
What should i do what do you think the problem is ? and would you start your car up frozen with "lots" of ice on it for the last 2 days knowing something could be wrong with it and the cooling fans will come on causing it to get warm slow cant be good for it.
Next time i start her up ill double check but I'm 95% sure they come on when you start up :<
Help much appreciated
