Hi All,
I have a 2018 Seat Leon Cupra 290 and I'm having a couple of issues with it.
When auto hold is disabled, the electronic parking brake doesn't engage when turning off the ignition so I have to pull it up manually.
There's been many times where I've forgotten to pull it up and it's just sitting on the tranmission locking pin which isn't good for it.
Its done this since day 1 of ownership and I just put it down to poor design on SEAT's side.
I'm trying to figure out if it would be possible to use VCDS to change the behavior of the EPB.
Secondly, when I switch off the ignition without removing the key, the indicators double flash and the doors just unlock themselves.
It used to stay locked until I removed the key from the ignition switch.
Any help would be greatly appreciated
Thank you.
Thank you.
