2days ago i recieved a cruise control retrofit kit, i fitted the new stalk and all the wiring except the cable to the engine bay since i didnt have time at that moment.
The car worked as previous after fitting this kit.
Today i went on to remove the ECU and grind away the "cage" around the ECU connector and i was also fiddling around behind the dash, above the pedals in the cabin to try and find the rubbet grommet which i should pass through the last cable for the cruise control retrofit.
But without success, so i bolted everything together again and now i seem to have caused a few problems..
The following things do NOT work:
-Brake lights
-Indicator stalk do not work in any direction, no clicking and no indicators turns on
-Interior light is ON in all times, no matter if the door is open or not. If i put it to the "off" position it turns off, but when its supposed to turn on when a door opens its lit all the time.
Indicators work fine when i turn on the hazards.
I get a fault code on brake light switch, implausible signal when i try to brake.
Any ideas on what i might have messed up? Any pointers to where i should start looking would be appreciated..
Worth mentioning is that i have no codes except the code for brake light switch. It pops up after braking.
-Brake lights
