Electronic Display - LCD
Sunburn
Hey guys,
Just picked up a Cupra r and on the way back realised the center consol which displays temp, fan speed etc etc is not displaying correctly, ie the segemnets that make up the nubers or words in the display are not working fully ie a number 8 looks like 3
so my question is can these displays be fixed easily? if so how and where can i get the parts?
cheers for your help all :)
vinylrichy
Darker Than The Vinyl
Aug 3, 2006
51
Worthing West Sussex
Hey guys,
Hi
i wouldnt mind knowing too - my display looks like its bleeding :cry:
toledo399
Assuming you have the dual climate control with individual temperature controls for each side of the car you could try the following which will reset the system. Press the “ECON” - key and the key for “air flow into the passenger compartment at face level” (the smaller button in the midlle) at the same time. The display will show a mass of symbols for a few seconds coupled with some sounds from the system as it resets. If you are lucky this may clear the problem.
