Guys,
My X plate 1.6 Leon recently had the gearbox replaced.It has been running fine up til tonight when going round a corner, the locks started jumping open then locked, the dash lit up like a christmas tree and all electrics were flickering on and off including the engine jumping on and off.
A check under the bonnet found a quick disconnect clip sitting above (i think) the starter motor just above the gearbox. I removed the battery to inspect for broken cable or bad connection, and upon reassembly, all I get on the dash now is the battery light which stays on permanently. There is now nothing electrical working at all.
I wonder if this cable or connection has somehow been affected by the gearbox removal/reinstallation?
Any help appreciated....
