mikeymay
The front electric window on drivers side has packed up today.
I can hear the motor running and can manually move the window if I try and put the window donw or back up (it doesn't work with the switch).
I am in the process of re sealing the ancillary panel as it leaks and when I slide my hand under the panel I can feel a metal wire hanging loose that I assume needs to be in the runner somehow. I can feel the same wire being flush to the runner on the other runner. Unfortunately I can't get the whole panel off as this would mean push the window all the way down and I am a bit scared that I won't be able to get it back up again!!!
Can I put the window all the way down and get back up again easy? Is this a common problem. I think maybe the wire has just popped off the runner somehow.
I would like to sort this before I re seal as would mean breaking the seal and having to re re seal again if I don;t do it today!!!
Any help would be appreciated.
Ps I have a '99 Toledo S TDi
