electric window problem
Mckellar
Copied this off ebay and wondering if anyone knows of anywhere that i could pick one up for cheaply or anyone has one lying around *hopeful*
This will fix all regulator faults:Motor sounds but the glass does not move, glass dropped to one side, or fallen into the door! (Caused by the plastic clamps breaking)
Or noisy grinding operation or jamming (Caused by broken, twisted ,corroded or fraying cables/spool)
i believe my window regulator has gone, so its sitting with a block of wood stuck up the door :(
makes a really nasty sounding grinding noise.
anyone know any scrappies etc i could phone too?
cheers, David
Mckellar
ive pm'd the guy and he hasnt got back to me yet.
either hes not been online or no reply is an awkward way of saying "no":(
Mckellar
andyj said:
sounds like the cable has actually frayed and jammed up inside the regulator/motor.
same thing has happened on 4 Ibiza's/Cordy's I've owned !!! lol
also is there a way i could just unjam the motor?
that wud save a few probs i suppose
ibiza_95
1.8T MK2 Conversion
if its a grinding noise id say its most likely to be the mechanism thats gone. mines gone twice now, and when the cable starts to fray and twist it starts sounding like the mechanism is chewing the cable up. the motor will probably be fine, but then i bet its cheaper to buy the whole thing as opposed to just the mechanism.
once the cable has gone tho you cant fix it
Mckellar
if i can get somewhere sheltered tonght i might strip the door down and see whats actually hapening.
it sounds more like the cable is just fraying, cos the motor still wants to spin.
Mckellar
do the components from a polo fit does anyone know, plenty on ebay!
Mckellar
yep the mk3 doors do fit, i jus now need to get one thats breaking, trying to source parts for an ibiza aint half hard, next car ! 1.2 corsa SXI!!
joking, but at least theres 10's of thousands being broken, spose thats good though :p
