Electric Window Problem
bgmowen
Hows it going guys? Proud owner of a Leon since September but I have a little Problem. On the Drivers door, The Drivers Window button has sort of popped out it is very challenging to get the window to move up or down. However the button for the passenger side works fine. Is there a way i could easily fix this?
b1nuzz
271
Bristol
The best way to check will be to take the door card out, and then remove the switch unit. You can then unscrew it to see if the rocker switch is either broken or dislodged etc.
let me know if you need a guide as to how to do this.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
You don't need to remove the door card. The switch unit pops out if you get a small flat bladed screwdriver under it. Quite a few people have had the switches collapse but usually on the passenger side. The drivers side switch will be more expensive to replace due to it's size and number of buttons etc.. The part number should be on the back to ask a dealer/form sponsor or you might get lucky on ebay/breakers yard.
Coalesy
Leon FR 20vt
Sep 16, 2008
76
Dronfield
yeah the full unit for drivers door is about 35 + vat from dealer, thats if its got rear elecy windows aswell. if not its about 30.. it think anyway off the top of my head
b1nuzz
271
Bristol
Part number is 1J4 959 857 D for the switch with all 4 windows and the lockout for the rear windows.
and yeah, i think it is about £35.00
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
I have one in the garage im pretty sure. Cant PM you as you dont have 10 posts so when you have click on my username on the right and private message me and will sort it out.
bgmowen
Awesome guys. I do just have electric windows in the front and not in the rear
bgmowen
Ach well thanks anyway. Going to have a good look at it this weekend when its not dark and freezing up here.
