easyryder1978
hi. My driver side window will not close. I took off the door panel and can see under the metal plate that the cable has got twisted up. I have done a search and it seems like i need to replace the pulley system. The only trouble is i cant remove the metal plate that the window sits behind. Do i need to get the window up before i can remove the metal plate? I see i have to remove the lock mechanism but i do not have the special tool to remove the two screws holding it in. Where can i get one of these tools from? I would be very grateful for any help. Thanks
