ecu swap, ok?
jimmy2006
116
I have a mk3 ibiza cupra t and wanting to get it revo'd, if i was to get an ecu off another ibiza exactly the same as mine (same ecu no's etc) that has the revo upgrade would it be a straight swap and would it work ok? or are there other things to consider?
May 2, 2006
2,758
would have thought a swap would have been fine on a stage 1 revo, stage 2 you would require hardware modifications to take full advantage of the software
flashbsd
its a 5 min job, see the stickys at the top of the vagcom section about ecu swapping.
3 posts in a week about this.
ibiza-cupra
494
castleford
what do you mean by hardware,as in decat etc
jonesya3
603
Liverpool
ibiza-cupra said:
oh yeah silly me,its just it seemed a little off topic:blink:
p.s i could of fit you a water pump and a belt for £180;)
Just got it done afew weeks back cost me £280 for the water pump and belt ect.... but thanks for the offer :D
May 2, 2006
2,758
4bar FPR, full system exhaust including race cat and DP, decent filtration, also FMIC and TIP would be ideal but not necessary
the list could be endless, depends how far you want to go
May 2, 2006
2,758
stage 1 can go on a standard car mate, its stage 2 you need the extra hardware for
stage 1 you will be seeing approx 195bhp, maybe more
jimmy2006
116
yeah, was just hoping to maybe save a few quid as there is one on ebay at the mo with the stage 2 software on it. oh well. anyone got a stage 1 revo'd ecu going?
May 2, 2006
2,758
buy it then, it will still work, just not as well as with the hardware to compliment it, if you bought the hardware at a later date then happy days, when you fit the harware all will be good :clap:
Ibiza Cupra
So what would you expect a standard engine on REVO STAGE
2 to be running???
jimmy2006
116
so it would suffer from detination etc if everything wasnt there to compliment the map? ie no exhaust, filter, no decat/sports cat etc. ?
May 2, 2006
2,758
it would suffer alot yes, better going with stage 1, buying your bits and bobs, fitting them and upgrading to stage 2
May 2, 2006
2,758
speak to some one like revokev, or one of the other revo guys, he will fill you in on anything you need to know matey regarding revo
jimmy2006
116
think i will just go for the stage one generic software as it is something which needs to be right. cheers for the reply's
jonesya3
603
Liverpool
The ecu on ebay is ibiza-cupra's the bo selecta one above, been looking at it myself ;) :)
