Hi,
I've had startup issues on my Leon for some time.
Got so bad that I had to bring it to the garage.
Issue has been diagnosed as an ECU fault.
Brand new the ECU is around £1200.
Not sure how much one in a breakers would be.
Particular model also seems hard to find.
Does anybody have any opinions/reccommendations on ECU repairs?
If I get one from a breakers I'd be worried that the same issue could appear on another one.
I figure that if the particular fault is repaired on the ECU then that same fault is less likely to re-appear.
I've seen places that repair an ECU if you send it to them.
Others will send you a refurbed ECU and then you send them your own one.
http://www.ecutesting.com/catalogue/product/volkswagen_golf_ecu_engine_management_eem012221.html
http://www.ecutechnologies.co.uk/ecus/207_EDC_16U1.php
