Couple of (probably) silly questions
All the pics i've seen of the ultimax discs have black centres, and silver discs. Mine are completely black. Is the black on the disc some sort of coating which needs to be removed? If so, with what? meths? white spirit?
Secondly, the two disc boxes are marked left hand / right hand. From what perspective - sitting in the driver's seat, or looking at the car from the front? I'm guessing that left hand means the passenger side?
Here's a pic of the 'right hand' disc to illustrate my two questions:
As you can see from the pic on the box, only the centre of the disc is black. Also, the black coating already has bits missing, so should i try and remove it all? Is this disc the driver's side one?
I've also just noticed that my discs have more than the required 5 wheel bolt holes. Any one else running the ultimax discs, do yours like look mine?
