Earthing point for jump leads?
Hamzilla
352
Watford, Herts
Hi,
Where is a safe earthing point on my engine bay so I can jump start it?
The instructions with the leads advise NOT to use the battery negative point.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I can't think why not to earth using the battery terminal... it's all the same electrically
Apr 12, 2008
1,197
because you creating a very close earth. can get hot damage the battery, and liable to spark. Apparently. i never seen it happen.
The only reason i dont do it, is if one of teh crock clips pings off, which they do, and touches they other one. Your in a whole heap of ****
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Engine block or chassis, as above supposed to prevent damage to electrical items i e the ECU.
Also connect the live red + first then the black - negative.
dav3
devilishd4ve xbox tag
Mar 29, 2007
655
Essex
As above engine block (lifting eye). This is the easiest/quickest way to jump a car as it charges the system rather than the battery 1st then the system.
