I just posted this in the thread about sump plugs but realized many people might not see it so thought I'd just copy it to here under it's own heading as I think it's very interesting.
Oh dear. I just keep on finding more things to worry me about my Ibiza's wee 1.0 3 cylinder CHZB engine. She's going to get her cam belt renewed at her next service time (Easter next year when she will be 5 years old)
As many will know this new(ish) EA211 engine series does not have it's water pump integrated into the cambelt drive train - It's actually on the "back end" of the cylinder head - flywheel end - and is driven by it's own wee synchronous belt. Of course this means that should it pack in it's not going to potentially right off the valve gear/engine (as long as you "catch it" before the engine cooks off).
The trouble is I've become so used to automatically doing a water pump when changing a cam belt that it's seeming strange not to do one this time? Seat don't quote a change interval as far as I'm aware, and why should they? The engines of old, including my VE engined 1.9tdi Cordoba, were the same and you just kept an eye on coolant level and weeping from the pump.
Anyway, feeling "nervous" about it I've been researching how easy it is to do the pump and I've come upon the attached guidance. I know these engines have separate coolant circulation for head and block and it's very interesting to see there are actually two thermostats to control this - oh dear, more "needless" complexity and "stuff" to go wrong? It's very interesting also to read that there are leakage problems due to warping of the plastic housing. I've recently had a very interesting time trying to sort an oil leak on my boy's '07 Astra 1600 VVT. After struggling valiantly with new seals etc I discovered, by talking to our local Vauxhall indy that these plastic covers are famous, not only for warping but also for the built in PCV valve to stop working - which causes running problems. Don't struggle with it, just fit a new cover complete! Is it just me that thinks a plastic component heated up to "pretty hot and then some" is going to distort? Forgone conclusion I would say?
So. Have a read of the attached and start to feel sorry for me. I knew I should have bought that 1.8 ivtec estate instead?
