Dyno results. Problem with N75???
limpabit
63
Hi everyone.
Got the car mapped and dyno'ed yesterday. It did not make as much as expected.
But does the boost control for the N75 look normal?
limpabit
63
It's a biggish T28 from a Nissan Pulsar. Just wondered if the steady increase in boost is normal for the N75.
Max boost was about 17-18 psi
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
That would depend on the mapping of the ECU.My stock K04 has a huge surge in boost, 1.7bar then drops holds 1.5bar which then tails off gradually to about 1bar at redline.
Also from the Dyno, it says MBAR x 0.1, you reached Max=126 according to the graph, so 126 x 0.1 = 12.6psi.I am not sure when you are getting 17psi from.
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
1 millibar = 0.0145037738
max mbar = 1260
max psi = 18.27
