dv reversal
Cupra-cal
139
Penicuik
is reversing a forge 007p dv gonna damage my engine? been watchin some vids on you tube where some people have said it is not a good idea.:confused::wtf:
Cupra-cal
139
Penicuik
DPJ, i never they said they were experts.all i said was i d seen it on you tube and wondered if it was true.as i know very little about the mechanics or tuning of engines,etc i can only go on what i seen hence the reason am on here asking.
S17EW O
im interested what the effects of turning it around are.....
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
in reverse the boost pressure acts on the base of the piston in direct opposite to the spring, so one benefit is it may drop boost quicker, but on the other hand it has more of a chance to leak boost too, in comparison of it acting on the side of the piston,
most dv do work as standard in the reverse position, i never understood why VAG fitted it the way they did, all i could think was due to the annoying little chirp it does in reverse,
ashley600
193
leicester
mines in reverse at the mo, it makes a squeak rather than a pissch. think i'll turn i around again and dremmel the engine cover so it fits better due to the silicone TIP.
Aug 24, 2007
800
think mine is reversed and has been for ages, no issues at all and no chirping noise. A dirty big cone filter helps loads :D
S17EW O
forgive me if im wrong but isnt the pipe on the top alot smaller than the pipe on the bottom?? how do you get around this, also while im here, little question, where the little pipe goes from the dumpvalve, bypas the 249 then follow it down and it connects onto the inlet manifold on the underside on the left, which of those 2 smal pipes does it connect to, had my mani off and not 100% ive got them the right way round....
S17EW O
wayne im as blagged as you, lol, just noticed your headlights look dark.....how have you done this?
S17EW O
nipple being the smallest pipe, so its actually the other 2 you swap, the 2 fat ones?
Aug 24, 2007
800
inlet and outlet of the DV is 25mm, so yes you swap their positions :)
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
nice 1 james so which do you think is the best way ?
never tried it reversed but logically reversed should be better, but the gay chirp you get would annoy me... cant see any real benefits either way tbh.
id leave it alone and maybe concentrate on other effective mods:shrug:
