broken
my arosa dumps all the oil out from the dipstick tube unless you detach the crankcase breather from the airbox, when its detached you can hear the oil gurgling so the oil is pressurised and the oil under the cap is a bit milky but nothing wrong in the water reservoir. i think its the piston rings, disregarding the milky oil as i heard this is an unrelated common fault. id just like to know if anybody has a simpler solution that doesnt mean i have to go to all the hassle of replacing my engine.
The user name obviously symbolizes your car lol. Just out of curiosity how many miles has it done?
around 55000 miles. went to scrapyard yesterday and found a polo engine dunno what engines are fully compatible yet need to do some web surfing tomorrow anyway the ****** wanted £125 for the engine i could probably get one for 75 tho if i deal with the right people. the main worry is getting an engine that looks the same but the sensors give off different readings or whatever other problems there may be....
if your looking to save yourself a major headache i would stick with teh same engine code as this will save you changing anything other than the gubbed engine block
