is it true that Cupra T's come with a re-circlatory dump valve as standard?
Sumpy840 Guest May 20, 2006 #1 is it true that Cupra T's come with a re-circlatory dump valve as standard?
BHP Addict Back in a SEAT!! Jan 31, 2006 886 0 Birmingham May 20, 2006 #2 Yes mate, plastice bosch diaphram one. Better changing to forge 007P or bailey DV when you get round to it as the standard ones aren't the strongest TBH All other details about dump valves should be in the search mate
225 Full Member Feb 8, 2004 1,836 0 uk Visit site May 20, 2006 #4 and no you cant run an atmos with out problems no matter what anyone tells you.
gazjones Guest May 20, 2006 #5 yep plastic bosch ones are prone to failing even standard so an upgrade is a good thing the standard one is a diaphram and forge is a piston
