dump valve vaccum pipe where does it go?
jaydenturbo
58
hi all ive now worked out with the help from others that my dump valve and pipes connecting to it have been completly removed as i now want to refit a dump valve just wondering where the vaccum hose from the top of the dump valve gos into have found a little hose that has been blocked off and wondering if its this as pictured /?[URL=http://s1325.photobucket.com/user/mg1zr/media/IMAG1013_zps9dac839e.jpg.html] [/URL]
and just to check does the dump valve go where orange arrow is pointing and the recirculating hose going from dump valve go where blue arrow is pointing ? [URL=http://s1325.photobucket.com/user/mg1zr/media/pho_zps904e4f20.png.html] [/URL]
Ronin225
4,652
22
Worcester
Yes, blue and orange arrows to both the larger ports on the DV, the small vac line to operate it comes from one of the nipples under inlet mani (via N249 unless bypassed)
jaydenturbo
58
hi thanks for replys il get right on buying the stuff for it i need quick question what size is thepipe i will need that gos from dump valve to the where blue arrow is as im getting the recirculating one is it 25mm inlet diameter?
