Dump valve Coldside Relocation
RabReith89
402
Aberdeen, Scotland
Hi guys am thinging of doing the coldside relocation for more dump valve noise is this a hard job, If anyone can talk me thro this it would be great
Thanks Rab
daves ibiza
yes mate well worth doing. i put a t piece in between colside ic pipe and run a pipe back to intake . block up the charge pipe that runs along of your engine. if this aint good enough pal try searching its been coverd so many times its alot of information on here:)
Davem
145
Birmingham
As above basically. I think i bought all the stuff off ebay for about 35 quid.
T piece 63mm(i think)with a 25mm piece coming off.
25mm metal connector
25mm blocking plug.
25mm 1m straight pipe (will be plenty)
Took me about half hour to fit as had to take bumper off to cut some of the pipe to fit the t piece in nicely.
d/v stays cool now, used to heat up before and start to fail and not work correctly.
daves ibiza
and to have cold air going back into turbo instead of hot:headhurt:
