HamTyler
Ok, went to go out in the car earlier and following happened:
Turned on the ignition, all ok. Start the car, and there are no lights on any of the letters alongside the gear selector. The gear indicator in the instrument panel (normally shows PNDRS or something) is flashing with the 'surround' all in red. Can't move the gear lever. Pressing the button on the side of the gear lever gives me the relay clicking noise, but putting my foot on the brake pedal does not cause the little foot-pedal light on the dash to go out.
Turn off, turn on and try again, same result. Oddly, I can't take the key out of the ignition when I turn off. Try a couple more times and then it all starts working except that now my emission control light has come on..
Go for a drive, gearbox operating ok, no engine misfire etc, everything seems fine. Run the car in both auto and using paddles, no problems. Tried driving for abit with the revs up in one gear to see if the emission light clears - but it doesn't.
Am booked into the dealers on Weds, so will keep y'all posted. I know the VAG forums elsewhere have mentioned this (http://www.vwaudiforum.co.uk/forum/showthread.php?t=16053) but I don't know if anyone here has had similar experiences?
